Aantrek-momenten voor Ford
Locked
Post by BigBlockMopar » Tue Nov 16, 2004 6:53 pm
260, 289, 302
Fastener Type Torque Spec
Main cap bolts 60-70 ft.-lbs.
Outer main cap bolts, 35-40 ft.-lbs.
Connecting rod bolts 19-24 ft.-lbs. (40-45 ft.-lbs. for 289 HP Boss 302)
Cylinder head bolts 65-72 ft.-lbs.
Rocker arms 17-23 ft.-lbs.
Intake manifold bolts 23-25 ft.-lbs.
Oil pump bolt 23-28 ft.-lbs.
Cam bolts 40-45 ft.-lbs.
Cam thrust plate bolts 8-10 ft.-lbs.
Harmonic damper bolts 70-90 ft.-lbs.
Flywheel/flexplate bolts 75-85 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Front cover bolts 12-15 ft.-lbs.
351W
Fastener Type Torque Specs
Main cap bolts 95-105 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs.
Cylinder head bolts 90-100 ft.-lbs.
Harmonic damper bolt 70-90 ft.-lbs.
351C, 351M
Connecting rod bolts 40-45 ft.-lbs. (45-50 ft.-lbs. for Boss 351C)
Cylinder head bolts (Follow factory torque sequence) 105 ft.-lbs. (125 ft.-lbs. for Boss 351C)
Rocker arms (non-adjustable) 18-22 ft.-lbs.
5/16 in. intake manifold bolts 21-25 ft.-lbs.
3/8 in. intake manifold bolts 28-33 ft.-lbs.
Oil pump bolt 25 ft.-lbs.
Cam thrust plate bolts 9-12 ft.-lbs.
Front cover bolts 12-18 ft.-lbs.
429-460
Maincap bolts 95-105 ft.-lbs.
Cylinder head bolts 140 ft.-lbs.
Intake manifold bolts 25-30 ft.-lbs.
360, 390, 406, 427, 428 FE
Crossbolts for 406 and 427 40 ft.-lbs.
Connecting rod bolts 40-45 ft.-lbs. (53-58 ft.-lbs. for 406 and 427)
Cylinder head bolts 80-90 ft.-lbs. (100-110 ft.-lbs. for 1963-67 427) Rocker arm shaft bolts 40-45 ft.-lbs.
Intake manifold bolts 32-35 ft.-lbs.
Oil pump bolt 12-15 ft.-lbs.
:smoke:
Locked
